Can I Change the Direction of the Fan on a PXI Chassis?
Updated Jan 4, 2019
  • PXIe-1082
  • PXIe-1062Q
  • PXIe-1085
  • PXIe-1078
Can I change wind direction of PXI chassis Fan?
The wind has to flow outwards in order to keep the temperature low. And for this reason, there is no separate switch or hardware device that can change the wind direction.
The PXI Fan exists to cool the chassis because the chassis works and generates a lot of heat. It's powerful function of NI PXI Chassis. Below figure is one of the PXI cooling fan design. This link explains more detail.
