Cannot Change Sequence Name in TestStand
Updated Jan 4, 2019
  • TestStand
Whenever I try to change the name of a sequence in TestStand it throws an error that says "External component has thrown an exception" as shown in the image below.
This behavior can be the result having 2 sequences in the sequence window with the same name. If this has occurred, try deleting both of the sequences with the same name from the sequence file.
