Talon SRX Controller Not Responding Using LabVIEW for FRC
Updated Feb 22, 2018
  • roboRIO
Other
  • Cross the Road Electronics Talon SRX Motor Controller
I was using the beta version of the driver for the CTR Electronics Talon SRX controllers, and recently upgraded to the newest version. Now I am unable to run any code or example programs successfully. Even basic code that opens a reference to the device and gets the status provides me an error or no response. However, I am still able to successfully establish communication with the controller and self-test, update firmware, reset, etc.
You are running into errors executing your code because you first need to mass-compile the code containing the VIs from the new tool palette from CTRE before attempting to run your program.
