Real-Time Controller Crashes After Stopping LabVIEW FPGA Application
Updated Feb 12, 2018
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
  • NI-RIO
My application contains a host VI that calls into an FPGA VI. When stopping my host VI, my RT controller crashes. Why is this happening, and how can I fix it?
Your Real-Time or Windows controller will crash if you attempt to close a single FPGA reference multiple times in your host VI.  Calling Close FPGA VI Reference more than once will result in an error because each call attempts to deallocate the same memory.
To alleviate this issue, ensure that exactly one Close FPGA VI Reference VI is called for every Open FPGA VI Reference VI.
If crash behavior is still occurring, change the properties of the Close FPGA VI Reference to Close instead of the default setting Close and Reset if Last Reference
  1. Right click on the Close FPGA VI Reference function.
  2. Select the Close option from the menu
  • You should not branch the FPGA VI Reference wire in your program.  If you must branch the wire, take extra precaution that the reference is not closed until the entire program has finished accessing the reference.
  • You may see this behavior in NI-RIO version 2.1.4 and earlier. This does not occur in NI-RIO version 2.3 or later.
