InsightCM™ 3.2 Upgrade OSIsoft PI Historian Connection
Updated Feb 14, 2018
  • NI InsightCM
I have upgraded to InsightCM™ 3.2, and it does not look like the PI interface is the same. The manual says "PI Data Access" instead of "PI SDK", and there is no XML file that needs to be edited. How do set up my historian?
In InsightCM 3.2, we switched to the OSIsoft PI Asset Framework (AF) SDK. You'll need to install the OSIsoft PI AF Client. A link to the SDK is below:
PI AF SDK
Make sure that the PI System Access License from OSIsoft is installed and configured on the server machine.
