Control Analog Output of NI Motion Controller in MAX
Updated Feb 12, 2018
  • PCI-7344
  • PXI-7350
  • PCI-7330
  • PXI-7340
  • NI-Motion
I would like to test my motion card using Measurement and Automation Explorer (MAX), and want to directly control the analog output. How can I control the analog output directly from MAX?
The analog outputs on an NI motion controller cannot directly be controlled from Measurement & Automation Explorer.  You can indirectly control the Digital-to-Analog Converter from Measurement & Automation Explorer by performing a 1D interactive move when your axis is configured for a servo-motor. However, this will not give you direct control over the voltage.
The recommended way to use the analog outputs on an NI motion controller is to use the Load DAC.flx motion function in LabVIEW located in Vision and Motion»NI 73xx»Analog & Digital IO.
