Error -200284: Multifunction DAQ on Self Calibrate
Updated Oct 26, 2018
  • Multifunction I/O Device
While performing a calibration on a multifunction DAQ device using Calibration Executive, I receive an error at the Verify Counter step and can not continue with the Adjustment portion of the procedure.  The device can be reset and self-tested in MAX, but when attempting to self-calibrate the module the self-calibration fails with the following error:
 Error -200284, Some or all of the samples requested have not yet been acquired.
Firstly, attempt to repair the NI-DAQmx driver.  If this does not resolve the issue, it is likely that there is a hardware problem in the analog circuitry of the module.  Please contact NI support to troubleshoot further.
