First, there are a couple of things to ensure:
- Ensure your Real-Time target supports Embedded UI
- Ensure that you have enabled Embedded UI in NI MAX and restart the Real-Time target
- The Real-Time target must be running a VI or a deployed application in order to see it on the display.
Try different troubleshooting steps:
- Try different cables to connect between your Real-Time target and the monitor.
- Ensure that your monitor works properly when connected to something other than the Real-Time target (using the same port on the monitor).
- Contact NI Support.
