Unable to Launch Test Panel in NI MAX
Updated Dec 23, 2023
  • NI-Sync
  • NI-DMM
I am getting the following error when try to open a test panel:
Unable to launch test panels. Please confirm the software is installed correctly and that configuration support is included.
How can I resolve this?
Make sure that you have hardware drivers compatible with your operating system and version of LabVIEW.
If you have recently upgraded LabVIEW versions, make sure that you follow the correct order of installation with DAQmx installed after LabVIEW.
