Do I Need LabVIEW Installed Prior to Installing the Service Pack 1 (SP1) Release?
Updated Aug 16, 2018
I am interested in installing a LabVIEW SP1 release on my computer. Is it necessary to install the non-SP1 LabVIEW release first, or can I install LabVIEW SP1 without having the non-SP1 LabVIEW release installed?
You can install the SP1 release without having the non-SP1 release on your computer.
This is because each SP1 release is a major release of LabVIEW and is independent of the non-SP1 release, meaning it's not necessary to install the non-SP1 release first.
Also, if you have a license for the non-SP1 LabVIEW release, it will not necessarily activate the LabVIEW SP1 release unless you have an active SSP membership.
