Can't Find Motion VIs In LabVIEW
Updated May 3, 2018
  • PXI-7330
  • NI-Motion
  • I just opened a LabVIEW VI and it says it is missing VIs including the .flx VIs from the Motion palette. Where are they?
  • I recently made changes to my computer and am now missing my .flx VIs. Where are my Motion VIs?
  • I upgraded LabVIEW and now I can't find my NI Motion VIs.
Make sure that your version of LabVIEW is compatible with your version of NI Motion. You can check the NI-Motion Compatibility chart to tell if you need to change versions.
