Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
Benchmarking Sections of Code in LabVIEW
Updated Aug 25, 2021
I have a program in LabVIEW that uses a while loop, and I want to know how long it takes for my while loop to iterate. I am acquiring data that is continuously changing, but there is a delay between when the data changes and when I see this update in my program. How can I tell if my while loop is causing this delay? How can I benchmark my while loop?
You can benchmark how long it takes to iterate through a while loop by using the Tick Count (ms) VI.
This takes the current time in milliseconds and subtracts it from the time during the previous iteration, which is saved in the shift register.
You can code an alternate version that uses a Feedback Note instead of Shift Registers. You just need to drop the following code inside your while loop and get the Iteration time (ms) without any modification to your original code.
If your while loop is taking a significant amount of time to execute each iteration, you may want to consider using multiple while loops. Implementing a producer/consumer architecture can help reduce the time it takes to iterate through each while loop, and prevent data loss.
