Bridge Configuration Failed in FRC Radio Configuration Utility
Updated Apr 25, 2023
  • roboRIO-FRC
  • roboRIO
  • LabVIEW Robotics Module for FRC
When I go to configure my robot radio or wireless bridge for FIRST Robotics Competition (FRC), the utility throws an error saying: could not locate my bridge
The following are common solutions for this error:
  • Ensure you're using the powered ethernet cable that came with the radio
  • Ensure your radio is directly connected to your PC, not connected through your roboRIO
  • Follow the instructions in WPI's Programming your Radio guide
