Although not natively selectable in AVG, RS-170 format signals can be generated based on their similarity to NTSC.
To configure the AVG for RS-170 generation, follow these steps:
- Choose M-NTSC from the Video format list.
- On the Appearance tab, configure the following settings:
- In the Level Settings, set Saturation factor to
0. - In the Timing Settings, set Sample frequency (Hz) to
20.034 M.
- On the Sync, Burst and Noise tab, in the Color Burst Parameters, set Burst amplitude (Pk-Pk) to
0. - On the Filters and Levels tab, configure the following settings:
- In the Filters settings, set I filter to Off.
- In the Filters settings, set Q filter to Off.
After completing this configuration, AVG should generate video per the RS-170 video standard.
