Drag & Drop Disabled for Array Elements in the TestStand Variables View
Updated May 3, 2018
  • TestStand
I am trying to reorder elements in my TestStand array variables using drag & drop in the variables pane, but I am unable to do so.  Why is this feature not working?
The drag & drop feature will not function for arrays if a sort is applied to any column in the variables pane, as shown below.
In order to use the feature, click the currently sorted column header until an arrow is no longer present. This behavior affects locals, file globals, and station globals,but not parameters.
The ability to drag & drop array elements was introduced in TestStand 2012
