"Nisuite.xml Not Found At Path" Error When Installing 2018 FRC Update Suite
Updated Feb 5, 2018
Other
FRC 2018 Update Suite
When I install the 2018 FRC Update Suite, I get the following error during installation:
"nisuite.xml not found at path" followed by a path in my C: drive in the /users/ folder. Why?
This issue can sometimes occur if the users network has certain firewall settings or administrator privileges blocked. Try running the installer as administrator, and make sure you have followed the Installing LabVIEW for FRC 2018 instructions completely, including uninstalling all previous NI software before proceeding with the 2018 software installation.
If the error persists, or you do not have administrator access on your machine, please contact your IT administrator and have them fully uninstall all NI software and reinstall LabVIEW 2017 and the 2018 Update Suite with administrator privileges.
