Web Publishing Tool Error: You can Embed Only Standard VIs
Updated May 3, 2018
I am receiving an error while trying to publish a VI using Web Publishing Tool in LabVIEW.
You can embed only standard VIs for remote front panel connections.
This can be caused by selecting a VI that is in a different version of LabVIEW. Open the VI and ensure that it is saved in the same version that you have launched Web Publishing Tool from.
