What Software do I Need to Use Inertia Add On for VeriStand?
Updated Feb 1, 2018
  • VeriStand
  • Wineman Technology INERTIA
  • LabVIEW Real-Time Module
I am trying to use the Inertia Add On for VeriStand but I don't know what software I need to do so.
All of the software you will need to use for this set up is one to one version support so all versions of software need to be the same with the exception of drivers. Typically the Inertia version on our website is the newest version of the Add On, but if you need different versions contact Wineman Technology support to inquire about what versions are available.The software installation order is as follows:
  1. LabVIEW
  2. LabVIEW Real Time Module
  3. Drivers
  4. VeriStand
  5. Inertia Add On
One issue we have seen with this installation is that there can be file path errors, but to fix those just open the VIs in the respective version of LabVIEW and manually resolve the file paths. For additional support with the Add On itself Wineman Support is the best path forward but National Instruments support can also try to assist with these issues.
Wineman Technology: https://www.winemantech.com/contact/
