DAQmx Error -200920 at DAQmxStartTask
Updated Feb 9, 2018
Programming Language
  • C
I'm getting error -200920 at DAQmxStartTask. The error says:
NON-FATAL RUN-TIME ERROR:  Function DAQmxWriteAnalogF64: (return value == -200920 [0xfffcef28]). Requested Every N Samples Event Interval is not supported for the given buffer size.  Modify the buffer size and/or the Every N Samples Event Interval so the buffer size is an even multiple of the Every N Samples Event Interval.
Why is this happening, and how can I fix it?
To fix this, make your buffer size an even multiple of the nSamples input to DAQmxRegisterEveryNSamplesEvent. The error will be thrown unless that is the case.
