Reset the IP Address to Default of the NI USRP-29xx
Updated Jan 30, 2018
  • USRP-2920
  • USRP-2921
  • USRP-2922
  • USRP-2940
  • USRP-2942
  • USRP-2943
  • USRP-2944
  • USRP-2945
I am unable to change the IP address of the NI USRP-29xx through the NI USRP Configuration Utility. How can I reset the device to the default IP address?
You may need to power cycle the device into a safe (read-only) image, if you cannot see your NI USRP-29xx device in the NI-USRP Configuration Utility and are unable to reset the IP address. When you have done this, it will reset the device's IP to the default value of 192.168.10.2. For step-by-step instructions, you can see the Why Doesn't the Device IP Address Reset to the Default?​ section located in your NI USRP 2920/2921/2922 Getting Started Guide.
