PXIe Controller Cores Selection
Updated Feb 9, 2018
  • PXIe-8880
  • PXI Controller
Is there a way for me to select the option of how many CPU cores my PXI(e) controller is using? What is this option called?
Yes, the number of CPU cores can be specified under the CPU configuration menu in the BIOS. This alternative setting is called "Enabled CPU Cores" and it allows you to select the number of active CPU cores for the processor. The valid values vary based on controller and can be found in your controller's User Manual.
