NI 5922 Input Range Configuration
Updated Jan 26, 2018
  • PCI-5922
  • PXI-5922
I see that the 5922 has two possible software controlled input ranges, 2V pk-pk and 10V pk-pk. How do I configure the input ranges of my NI 5922 device? What is the default value?
In the NI-SCOPE Soft Front Panel, you can see that it defaults to 10V pk-pk if you click the Prop button and then look under Vertical>>Vertical Range.
You can configure this in LabVIEW by altering the value wired into the Vertical Range terminal of the Configure Vertical VI in the Scope API.
