When I try to open any NI software I get an error indicating that the msvcp140.dll is missing or has an error, how can I get fix this and get the software to open?
Example scenario:
- I can call LabVIEW code from TestStand when the LabVIEW Development Environment is installed. However, if only the LabVIEW Run-Time Engine is installed, calling LabVIEW code with the RTE gives the missing DLL error.
- I uninstalled several software from my cDAQ controller and after trying to run LabVIEW it gave missing MSVCP140.dll error.
- I receive an error message detailing "the program can't start because msvcp140.dll is missing from your computer.”
Addtionally when I try to install some National Instruments software I receive the following error:
