In order to convert a boolean array into a fixed point number, you can convert the boolean array into an integer using the
To Word Integer Function, then convert that into a fixed point number by using the
Integer to Fixed-Point Cast Function . This function uses an arithmetic shift of the input to ensure that the least significant bit of the input becomes the least significant bit of the output.
