Timer On Delay Function Block Does Not Respond if Input Is True by Default
Updated Apr 25, 2018
My Timer On Delay Function Block does not work correctly if the input signal is true by default. I have to wait until it switches from false to true for it to work. How can I fix this?
Timer On Delay responds to rising edges at the input, not just high signals. Because of this, it will not trigger if the input is set to true by default.
