Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
Third-Party Tools for Reading and Writing to TDM/TDMS Files
Updated Dec 10, 2025
Other
  • Notepad
  • Microsoft Excel
  • MATLAB
  • OpenOffice.org Calc
  • Python
How can I read and write TDM/TDMS files with software products that are not designed by NI?
The section 'Writing and Reading TDMS Files with Third-Party Programming Software' from the NI TDMS File Format document addresses multiple tools recommended by NI to read and write to TDM/TDMS files using third-party software. These consist of the TDM C DLL the OpenOffice.org Calc and MATLAB TDM Example User Guide
In addition to those, it is possible to interface with TDM/TDMS files through TDM Excel Add-In Tool for Microsoft Excel User Guide and Notepad. In DIAdem 2018 and later, metadata is compressed by default to minimize the file size. To interface with TDM/TDMS files developed in those DIAdem versions using Notepad, make sure TDM/TDMS files metadata is not being compressed. Metadata compression settings can be found in DIAdem Settings: NAVIGATOR dialog box
npTDMS is a tool for interfacing with TDMS Files using Python.
