Use this example if you only want to take screenshots from your LabVIEW IDE:
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project. To use a
snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
Use this example if you want to take screenshots from the IDE or an EXE:
