VeriStand UI Manager Crashes When I Change the Parameter Access
Updated Feb 14, 2018
  • VeriStand 2016
  • VeriStand 2017 PC
  • VeriStand 2017 Full
  • VeriStand 2016 Media
VeriStand UI Manager crashes with an unknown error when I change the Parameter Access in the Simulation Models settings in the System Explorer to allow reading and writing any parameter.
The error message:
This is a known issue that has been reported and addressed in VeriStand 2017. To solve this, you can either:
  • Upgrade to VeriStand 2017, which has this issue fixed.
  • Workaround this issue in VeriStand 2016 by using the other option in the Parameter Access menu "Only Allow Reading and Writing Imported Parameters".
