cRIO Embedded UI Does Not Support Localized Version of the Real-Time Module
Updated Jan 29, 2018
  • cRIO-9038
  • cRIO-9039
  • cRIO-9037
  • cRIO-9035
  • cRIO-9034
  • cRIO-9032
  • cRIO-9031
  • cRIO-9030
  • cRIO-9033
  • cRIO-9036
  • LabVIEW Real-Time Module
My target RT (cRIO-9038) had installed localized version of Real-Time Module but the Enable Embedded UI was disabled and greyed out in NI-MAX.
LabVIEW Real-Time Module Help File states that the Embedded UI does not support localized version of the Real-Time Module. Alternatively you can use Web-Based Thin Client for Embedded UI.
