"Data Type: Network Disabled" in the Distributed System Manager
Updated May 3, 2018
Other
When trying to read the variables in the Distributed System Manager, I can't interact with them. They appear as Data Type: Network Disabled.
  1. Go to the LabVIEW project.
  2. Find your variable.
  3. Right click>>properties.
  4. In the Properties, under Variable, make sure "Enable Network Variable" is checked. (You may need to change the Variable type).
You will then need to rebuild and redeploy the application, as well as restart the Distributed System Manger.
