Other Controllers for Direct cDAQ Communication
Industrial Controllers
The IC-317x line of controllers have the TSN capability, run NI Linux Real-Time OS
‡, and supports NI-DAQmx: IC-3171, IC-3172, IC-3173.
‡ Please note some devices are not supported by Real-Time controllers: cDAQ-9181, cDAQ-9184, cDAQ-9188, cDAQ-9188XT, and cDAQ-9191. Refer to the DAQmx
readme for more information regarding compatibility between devices.
cDAQs with Built-in Controllers
The cDAQ-913x line contains a built-in controller that runs either NI Linux Real-Time OS or Windows Embedded 7 (WES7) and supports NI-DAQmx: cDAQ-9132, cDAQ-9133, cDAQ-9134, cDAQ-9135, cDAQ-9136, cDAQ-9137. These cDAQs have the controller built in, so they do not require a PC or another system in order to run code.
USB cDAQs from the cDAQ-917x line can also be controlled by the cDAQ-913x line when plugged directly to the USB port of the cDAQ Controller.
Options for chassis expansion of embedded cDAQs will depend on the operating system of the controller.
cRIO I/O Expansion Options
If you need to have more I/Os for your cRIO, you can look at other options to expand your I/O such as:
