Archived:Error -234101 Or -234107 When Self-Calibrating My NI Oscilloscope
Updated Apr 10, 2025
  • PXI-5122
  • PXI-5124
  • PXI-5142
  • PXIe-5122
  • NI-SCOPE
When trying to self-calibrate my NI 5122, 5124, or 5142, I receive the following error:
 Error -234107 or -234101: Internal Hardware Error occurred in Scopes hardware. Please contact National Instruments Support.
These NI Oscilloscopes can have rare, false self-calibration failures. If you have NI-SCOPE version 2.8 or earlier installed, upgrade to NI-SCOPE 2.8.1 or later. If you are using the latest compatible version of NI-SCOPE and are still receiving this error, please contact NI Support as this error usually indicates a hardware failure and results in an RMA.
This error can occur in Measurement & Automation Explorer (MAX), NI-SCOPE Soft Front Panel, or an Application Development Environment (LabVIEW, LabWindows/CVI, Measurement Studio).
The error appears differently in different calibration environments:
Figure 1: LabVIEW Error
Figure 2: NI-SCOPE Soft Front Panel Error
Figure 3: NI-MAX Error
