Unlike with serial boards, a loop-back cannot be performed on the same port. However you can perform a loop-back test using the the Loopback Test.vi that can be found through the Example Finder. This VI works with any XNET device. To perform a loop-back test on your NI-XNET device, follow these instructions.
- Connect the 2 ports of your NI-XNET device together using an appropriate cable
- Open LabVIEW and select Help » Find Examples...
- Next navigate to the Search tab and search for Loopback.
4. Open this
CAN Loopback Test.vi and run the program.
