NI Package Manager Requires Latest Version or is Too Old Notification
Updated Apr 17, 2026
  • Package Manager
When attempting to install or uninstall NI software, I get an error stating that my version of NI Package Manager is too old.
This version of Package Manager is too old to handle newer installed software.
A package you selected, or one of its dependencies, requires the latest version of Package Manager to continue with the installation.
There are two scenarios where you can encounter these errors:
Not Using NI Package Manager Latest Version
These errors occur when there is a compatibility mismatch between NI Package Manager (NIPM) and the software involved.
  • The first error occurs when software already installed on the system requires a newer compatibility version than the currently installed version of NIPM supports.
  • The second error occurs when attempting to install a package that requires a newer compatibility version than the installed NIPM supports.
To resolve either issue, upgrade NI Package Manager to a newer version:
  • Open NI Package Manager and click on the Upgrade now banner at the top of the window to upgrade to the latest version.
  • Alternatively, you can download the offline installer from the NI Package Manager Download page.
If you are already using the latest version of NI Package Manager (NIPM) supported by your operating system, the issue may be caused by an incompatible package installed through a custom or standalone installer. In this case, try the following troubleshooting steps:
  1. Generate NIPM error logs - Generate the NI Package Manager error logs to gather more details about the issue and identify the component causing it. In particular, the agentsErrorLog.txt file can help pinpoint the problematic package.
    If you are unsure how to generate these logs, refer to Generating and Locating NI Package Manager Error Logs. Once the logs are generated, contact NI Support and include them for further troubleshooting.
  2. Remove incompatible software - If the logs indicate that a specific package is not compatible with your version of Windows, uninstall the unsupported software. This helps return NIPM to a healthy state. After removal, reinstall or update NI Package Manager as needed using the NI Package Manager Download page.
    In 2020, NI ended support for Windows 7. As a result, NI Package Manager (NIPM) 20.6 was the last version to support Windows 7, while NIPM 20.7 and later versions support only Windows 10 and newer operating systems.
    Any NI installer—whether legacy or package‑based—created on a system with NIPM 20.7 or later installed is blocked from running on a Windows 7 system. Although it is technically possible to modify an installer to bypass this operating system check, doing so is not recommended. Bypassing the restriction can install components that are designed to run only on Windows 10 or later, which may lead to errors during the installation or uninstallation of NI software.
