If Missing NI Package Manager Latest Version:
  The first error appears when you have software already installed on your system that has a higher compatibility version than that specified by the installed version of NIPM. The second error appears when you try to install a package with a higher compatibility version than that specified by the installed version of NIPM. To resolve these errors, upgrade your NIPM version:
- Open NI Package Manager and click on the Upgrade now banner at the top of the window to upgrade to the latest version. If restarting does not trigger an automatic update, move to the next step.
If Having NI Package Manager Latest Version Installed:
If you’re using the most up-to-date NI Package Manager compatible with your operating system, the issue might stem from an incompatible package installed via a custom installer. Try the following troubleshooting steps:
- Generate the NIPM-generated error logs to get additional information about the error and the component causing the issue. The file "agentsErrorLog.txt" can provide some insight into the package causing the error. If you do not know how to generate these log files take a look at Generating and Locating NI Package Manager Error Logs and contact NI with generated logs for further troubleshooting.
- If you identify that a specific package is not compatible with the Windows OS, remove the software that is not supported to get NIPM into a good state following NI Package Manager Download
