このコンテンツは設定された言語で表示できません。
Can't See cDAQ 9185/9189 in NI MAX
Updated Jan 13, 2026
  • cDAQ-9189
  • cDAQ-9185
  • NI-DAQmx 19.5
I can see my cDAQ9185/9189 in NI MAX when I have it directly connected to my computer via a crossover cable, but not when I have it connected over the network. Is there something blocking it?
If your cDAQ is TSN (Time Sensitive Network) enabled, it will not be seen. TSN uses the Rapid Spanning Tree Protocol (RSTP) to create a loopless network, which is not compatible with certain network settings.
From the DAQmx 19.5 release or later, you can disable RSTP for the TSN chassis. Complete instructions are available in Enabling and Disabling RSTP on FieldDAQ and CompactDAQ 9185 and 9189 Devices.
This feature is not present on previous releases of NI-DAQmx. You can configure your network devices differently to enable communication; for example, disabling Bridge Protocol Data Units (BPDU) guard will enable RSTP devices to work correctly. If it is not possible to configure your network differently, you should consider using a non-TSN cDAQ chassis, such as the cDAQ-9184 or cDAQ-9188.
Since the TSN cDAQ chassis have two network ports on them, it is possible to create a network loop. RSTP is implemented on these devices to keep such a loop from disrupting the network.
If you receive Error -201401 when trying to add modules in NI MAX, follow the steps in NI-MAX Error -201401: Retrieving Properties from the Network Device Failed .
