There are two methods for suppressing the Run-Time Error dialog box:
This article covers both approaches in detail.
Modifying the Station Options
TestStand allows you to define the execution behavior when a run-time error occurs, including not showing the error dialog. To achieve this:
- On the main menu, click Configure>>Station Options and select the Execution tab.
- Set the On Run-Time Error dropdown selector to Run Cleanup. According to the TestStand Help, this option "Causes the execution to jump to the Cleanup step group. If the error propagates normally to the calling sequence, the calling sequence also jumps to the Cleanup step group so the cleanup steps run for all active sequences and the execution terminates."
- Click OK to close the Station Options dialog.
- Run your sequence and force the error to happen. You'll notice that the dialog no longer shows up, but the final test status is still Error. You can hover your mouse over the step status or sequence file tab of the Steps View pane to get the full error message.
[Back to TOC]
Overriding the SequenceFilePostStepRunTimeError
This approach allows you to programmatically determine what to do when a step fails. You can not only suppress the run-time error dialog, but could display your custom error dialog, or even log that error to disk in a customized string format. Follow the steps below to hide the run-time error dialog and skip to cleanup:
- On the Sequences Pane, right click any blank area and select SequenceFileCallbacks... from the shortcut menu.
- Check the SequenceFilePostStepRuntimeError Engine Callback and click OK.
- Using Statement Steps, set the ErrorReported and GotoCleanup properties of the caller's sequence context to True.
RunState.Caller.ErrorReported = True
RunState.Caller.GotoCleanup = True
[Back to TOC]
