Synchronously Receiving Two FM Signals With LabVIEW
Updated Jan 19, 2018
  • NI-USRP
I am trying to create a LabVIEW project for Passive Radar which needs to receive two FM signals (one from the source and the other from the target) at the same time. Could you please send me a LabVIEW example that configures two receivers in a synchronous manner?
You can use the example entitled “niUSRP EX Rx Multiple Inputs (Single Device, Multi Channel)” in LabVIEW. This example configures a single device to use two RX Channels in a synchronous manner.
You can find it in the following path: C:\Program Files (x86)\National Instruments\LabVIEW 20xx\examples\instr\niUSRP
