There are two parts to running a LabVIEW in NI SignalExpress:
- Prepare the LabVIEW VI for SignalExpress. See the instructions for:
- Call the LabVIEW VI in SignalExpress
You must use LabVIEW 7.1 or later to create the VI used in the
Run LabVIEW VI step in LabVIEW SignalExpress.
You cannot run a VI that was saved for a previous LabVIEW version using the
Run LabVIEW VI step in LabVIEW Signal Express. You must save the VI in the actual version of LabVIEW you specify in the
Run LabVIEW VI step.
