Graph Palette Is Too Small or Display Graph Palette
Updated Jan 19, 2023
The buttons for graph palette tool are too small and are not handy to be used. Can I zoom the buttons or display multiple buttons in a row?
You cannot change these built in features, but you can create custom buttons that select the graph palette tools programmatically using the Palette:Active Tool Property .
  1. Create Boolean button for each tool you want to customize.
  2. In the block diagram, add a While Loop and an Event Structure .
  3. Add the Palette:Active Tool Property by right clicking on the Waveform Graph or Chart and select Create > Property Node > Palette > Active Tool.
  4. Wire the integer value to the property node to set the tool that is currently selected on the graph palette.
Input ValueGraph Palette
0selection cursor
1panning tool
2Zoom to Rectangle
3X-zoom
4Y-zoom
5Zoom to Fit
6Zoom Our
7Zoom In about Point
