Current Input Range of NI 9227
Updated Jan 26, 2018
  • NI-9227
I want to measure from negative to positive 1 Amp using the NI 9227, but it mentions a current input range of 5Arms. What is the range of current I can measure with this module?
The 9227 can measure from -5 to +5 Amps of current.
RMS is an standard reporting value, and refers to the steady DC value of the equivalent AC signal. However, this can vary depending on the signal characteristics.
