Archived:PCI Digitizer Does Not Have a Fan
Updated Dec 20, 2018
National Instruments does not actively maintain this document.
  • PCI-5114
  • PCI-5122
  • PCI-5142
  • I recently purchased a PCI digitizer and it doesn't have an onboard fan
  • There is a space on my PCI digitizer where it looks like there should be a fan
If you have just purchased a brand new digitizer or potentially received yours back from a repair, your board may no longer have a fan.  The PCI-5114, PCI-5122 and PCI-5142 modules will no longer ship with a fan.
National Instruments has determined that a typical PC will provide sufficient cooling for these modules, and the onboard fan is not necessary.  By removing this mechanical component, this engineering change will actually offer an improvement in long-term reliability.
​This change will have no negative impact on the performance of your device and there is no reason for concern.  It is still important to ensure your system provides optimal cooling to prolong the life of the components within.  Please refer to the Maintain Forced-Air Cooling Guide to verify that you are following the recommended techniques to optimize cooling.
