Can an NI R Series Data Acquisition (DAQ) Device Run in a PXI Chassis without a Controller?
Updated Jan 24, 2018
  • PXI Chassis
  • PXI Controller
R Series DAQ devices can be configured to run a compiled LabVIEW FPGA VI on power up. Is it possible for these boards to run headlessly?
Yes, but if you are not using a controller, you must use a MXI card in the controller slot of your PXI chassis. R Series boards were designed to run with a controller or MXI card in the chassis. Running these boards in a chassis without a controller or MXI card is not recommended, because the PXI lines have floating signals that could cause damage to the board. A MXI card would pull the digital lines down to ground.
