Which Experts Are Valid Inputs for System Configuration API Functions?
Updated Feb 9, 2018
I am trying to use the Find, Export, or Import functions from the System Configuration API in LabVIEW. I would like to filter the devices I see using the Experts input. What are valid strings for each driver when using the Experts input terminal/parameter?
To get all of the available experts terminal/parameter strings on a system, you can call the Get System Experts VI in the System Configuration API. This VI returns a string array of all the available experts strings on the selected system.
The following table is a list of supported product lines and their associated experts input strings. Note that some product lines may only be used with either the System Configuration Find or the Export/Import VIs, while others may be used with both. You may also leave the input empty to include all supported products.
Product LineProgrammatic NameWorks with FindWorks with Import/Export
CANopenni-canopen
cRIO**crio
Network Discovery Expert (mDNS)network
NI FlexRIO with Modular I/O*niflexrio
NI FlexRIO with Integrated I/Oniflexrio2
NI-488.2ni-488.2
NI-568xni-rfpowermeter
NI-845x845x
NI-DAQmxdaqmx
NI-DCPOWERdcpowerscx
NI-DCPOWERnidcpower416x
NI-DMMnidmmscx
NI-DMMnidmm408x
NI-OSIni-osi
NI-PTPni-1588
NI-PXImcni-pximc
NI-RIOni-rio
NI-RTSIrtsi
NI-Serialserial
NI-Sync***ni-sync
NI-VISAni-visa
NI-VNAnivna
NI VSTni-vst
NI-WSNni-wsn
NI-XNETxnet
PXI Platform Servicesni-pxi
SoftMotionmcSysApi
NI-SLSCslsc
*NI FlexRIO hardware was accessed through the NI-RIO expert prior to 2014
**With CompactRIO 14.1, the cRIO expert only supports acquiring temperature data on the sbRIO-9651.
***NI-Sync hardware is accessed through the NI-Sync expert on Linux desktop and LinuxRT systems. On Windows systems, NI-Sync hardware can be accessed through the NI-DAQmx expert.
