You can programmatically enable or disable Database Logging and/or Report Generation using the DatabaseOptions and ReportOptions Sequence File callbacks. Add the callbacks to your client sequence file and change the disable flags as follows.
Database Logging:
- Select Edit»Sequence File Callbacks.
- Select the DatabaseOptions Callback and click the Add button to add the callback to your client sequence file.
- Click OK to close the Sequence File Callbacks dialog box.
- Inside of your client sequence file, open the DatabaseOptions Callback.
- Insert a Statement step. Right-click and select Insert Step»Statement.
- For the expression, type Parameters.DatabaseOptions.DisableDatabaseLogging = True to disable Database Logging. Type Parameters.DatabaseOptions.DisableDatabaseLogging = False to enable Database Logging.
Report Generation:
- Select the ReportOptions Callback and click the Add button to add the callback to your client sequence file.
- Inside of your client sequence file, open the ReportOptions Callback.
- For the expression, type Parameters.ReportOptions.DisableReportGeneration = True to disable Report Generation. Type Parameters.ReportOptions.DisableReportGeneration = False
to enable Report Generation.
You can also override the ModelPluginOptions and ModelPluginConfiguration callbacks to edit the configuration of the Database Logging or Report Generation Plug-ins, refer to the following document for further details
Model Plug in Client-File Callbacks.
