RT PCIe Card Only Pulls Samples from the Buffer When Eight Samples Are Available
Updated May 29, 2018
  • PCIe-6323
  • LabVIEW 2015 Full
  • NI-DAQmx 15.0.1
  • NI Linux Real-Time
  • I am using a PCIe 6323 and a RT program. The RT program is not reading from the buffer until eights samples are in the buffer, even though I have set the DAQmx Read samples per channel as -1 which sounds like it should pull as soon as there are samples available.
  • How can I force my RT program to acquire samples from the buffer as soon as they are available?
There are a few methods to try to address this issue:
  • Try setting the "ReadAllAvaliSamp" Property node for the task to specify that all samples are read. Setting this property to True may help force the behavior.
  • Try setting the "Onboard Memory Not Empty" property node to force a transfer when there's a sample in the Onboard Memory.
  • Try setting the number of samples to read from the buffer rather than trying to read all available. Rather than specifying -1 in the DAQmx Read VI to read all samples, set a specific number of samples per channel. This ultimately gives you more control over the rate that samples are pulled from the buffer.
  • Try switching to Hardware Timed Single Point to bypass the buffer operations all together. This is recommended for control applications.
