Web Resource VIs Reset When Files Added to Web Service Project
Updated Jan 7, 2019
I am using LabVIEW 2014 and every time when I add files to my Web Service project, all the HTTPMethod VIs in Web Resources are reset to the default settings: "GET as Terminal/XML". Therefore, I have to set the parameters all over again for all the HTTPMethod VIs.
Figure 1. HTTP Method VI Settings
This is a known issue exists in LabVIEW prior to version 2015 and the issue has been fixed in LabVIEW 2015.
Try installing or upgrading to LabVIEW 2015 or later to fix the problem.
See LabVIEW 2015 Readme for Windows - Bug Fixes for a full list of the bugs fixed in LabVIEW 2015. The issue mentioned above is listed as CAR ID: 435756.
