Analog Input Range of the NI 5772 FAM
Updated Jan 19, 2018
  • NI-5772
What is the analog input range of the NI 5772 Digitizer FAM (FlexRIO Adapter Module)?
The NI 5772 has a maximum usable AI range of 2 Vpk-pk. This cannot be changed to a different value, although if you are using the AC coupled version and enable Time Interleaved Sampling, as described in the 5772 CLIP Help, this results in an AI range of 4 Vpk-pk.
The NI 5772 specifications list the Absolute maximum voltage as ±10 VDC, +21 dBm (7.1 Vpk-pk). This is referring to the maximum value the device can withstand without damage, but is not usable range. The ADC will clip any values below -1 V or above 1 V.
