Cooling Information for HDD 8266 Raid Array
Updated May 3, 2018
  • HDD-8266
How is the HDD 8266 cooled? Does it use heatsinks, fans, or some other cooling method?
There are four fans inside the HDD-8266 enclosure that blow air onto the hard drive array. There is also one fan attached to the PSU. For the RAID driver card inside the enclosure, there is a heatsink on all versions of this card. For the driver card used in the platter drive versions of the HDD 8266 (the non-solid-state-drive versions) there is also a fan attached to this heatsink. The SSD version does not need a fan on this heatsink, as it doesn't generate as much heat during use.
Acceptable operating ambient temperature for all versions of the HDD-8266 can be found in the specifications.
