Mapping NI CB-68LP/CB-68LPR Connector Block Pinout to NI DAQ Board
Updated Apr 8, 2025
  • CB-68LPR
  • CB-68LP
The connectors on my CB-68LP/CB-68LPR connector block are labeled "J1", "J10", etc., but the pins on my data acquisition (DAQ) board are labeled "1", "2", etc. What is the mapping of these pins?
  • The pins map 1-to-1. For example, pin "J10" on the CB-68LP/CB-68LPR corresponds to pin 10 on the 68-pin connector of your DAQ board.
  • In order to determine which pin corresponds to each physical channel on your DAQ device, you should consult your DAQ device's manual. The pinout for each of the DAQ device families (i.e. X Series, M Series, etc.) is different due to different capabilities.
You can use the below image as a reference to the layout of the terminals on your CB-68LPR:
